MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
cruisencode
Mar 14, 2020Apprentice
DBV wrote:That is the one that works though - right? I downgraded yesterday and is the one that I have.
Not for me. I have V3.1.5.23, and that works fine. As soon as it goes back to V3.2.9.2 (or V3.2.10.11) my issues return.
It makes no sense whatsoever why NG is still pushing this to our devices when it has been proven that it doesn't work for those of us that are having issues. This is unacceptible and I'm almost ready to dump this $700 headache.
Mar 14, 2020Guru - Experienced User
Id make contact with Christian_R and see what they can do for you.
- cruisencodeMar 14, 2020Apprentice
FURRYe38 wrote:Id make contact with Christian_R and see what they can do for you.
I did that and he didn't actually do anything. He just asked me a few questions.
- FURRYe38Mar 14, 2020Guru - Experienced User
I recommend you downgrade to v3.1 then:
Or use the Orbi AX in AP mode with your prior router.
Will need to be patient while NG works on this.
cruisencode wrote:I did that and he didn't actually do anything. He just asked me a few questions.
If you read my posts, I have been downgrading to V3.1 EVERY DAY. This is because NG keeps auto-upgrading me back to V3.2 EVERY NIGHT. This is a rediculous version of Groundhog Day that I can't seem to get out of.
- warpdagMar 14, 2020ApprenticeSame here, downgraded to get back to a stable state, and it re-upgraded against my will.
Since netgear forced me to buy an edgerouter to secure my connection, I’ll simply create a firewall rule to block their update server and then downgrade again (I bought the router since the WAN side of the Orbi was not safe for direct connection with the previous firmware... it looks like they noticed my posts, the new firmware might have fixed the issue according to the release notes, no wonder why they’re pushing the update aggressively). - FURRYe38Mar 14, 2020Guru - Experienced User
If you can get the Orbi to remain on older FW, use the Orbi AX in AP mode with your prior router.
cruisencode wrote:If you read my posts, I have been downgrading to V3.1 EVERY DAY. This is because NG keeps auto-upgrading me back to V3.2 EVERY NIGHT. This is a rediculous version of Groundhog Day that I can't seem to get out of.
- ZOOShenMar 15, 2020StarCould you tell me their upgrade server address?
- xnolightxMar 15, 2020Star
Actually, you can see their server. If you telnet into the router you can see the updates server by using the following command:
nvram show ver | sort
That will show you ftp and https servers. For example
ver_check_ftp_svr1=updates1.netgear.com
ver_check_ftp_svr2=updates1.netgear.com
ver_check_ftp_svr3=updates1.netgear.com :
ver_check_https_svr1=http.fw.updates1.netgear.com
So, in theory adding updates1.netgear.com to the blocked list should prevent the router from being able to pull automatic updates. I'm not 100% positive this will stop the nightly updating, but it appears to have prevented the web gui from knowing whether updates are available. You can confirm this by looking at the firmware update page. It will show service unreachable. I'm crossing my fingers that this will work, but I have to wait until midnight to know for sure.
- warpdagMar 15, 2020Apprentice
If you use an external router, you need to enable DNS forwarding on the router and then configure Orbi to use the router as its DNS server. Then, simply tweak the hosts file on the router. You can do it manually, or if you have an EdgeRouter like me, go to the CLI and try something like that:
set system static-host-mapping host-name updates1.netgear.com inet 127.0.0.1
set system static-host-mapping host-name http.fw.updates1.netgear.com inet 127.0.0.1
Commit and save and you're done.
Note: I use Orbi as AP, not as router. I use an EdgeRouter 4 for routing. Obviously, it doesn't work if you use Orbi as router and there is nothing in the way to block the requests to Netgear.
- d1mmyMar 15, 2020ApprenticeYou could potentially set the Orbi (as router) to manually use nextdns.io as its DNS. You would have to set up an account and then put a rule in to block the Netgear hostname(s) for their update servers. This assumed Netgear haven't hard coded their update server DNS in some way.
- d1mmyMar 15, 2020ApprenticeI should add that Netgear have "helpfully" moved the IPv6 DNS settings to the Advanced/IPv6 settings area and not in with IPv4 DNS, so if you enable IPv6, make sure to update both places.
- angelogouvisMar 15, 2020Guide
My attempts to block the upgrade by setting "install_fw_upgrade_latest=0" in firmware failed. The upgrade to 3.2.9.2 happened anyway.
I'll try what others have suggested above to see if I can block the router's path to the upgrade servers.
Unfortunatley, I no longer have my older router, so for me using the orbi as an AP won't work, and I'm not thrilled with the idea of buy *another* router.
- FURRYe38Mar 15, 2020Guru - Experienced User
I recommend that you download the v3.2.9.2 FW files to a wired PC. Manually load these files on to the RBS and RBR. Then factory reset the RBS and RBR by pressing the reset button in back for 15 seconds. Power OFF the ISP modem/ONT for 30 seconds then back ON. Walk thru the setup wizard with the wired PC and web browser.
angelogouvis wrote:My attempts to block the upgrade by setting "install_fw_upgrade_latest=0" in firmware failed. The upgrade to 3.2.9.2 happened anyway.
Thanks for the suggestion FURRYe38 . However, I've had good luck with the v3.1.5.23_1.0.46 firmware, and I'm inclined make efforts to keep that version in place until such time that Netgear offers an updated firmware that addresses these issues.
- quethrosarMar 15, 2020Star
any update on this ? i have v3.2.9.2. skype and anydesk disconnects every 10 to 15 minutes.
Ok, thanks for letting us know. Hopefully next update will correct things.
angelogouvis wrote:Thanks for the suggestion FURRYe38 . However, I've had good luck with the v3.1.5.23_1.0.46 firmware, and I'm inclined make efforts to keep that version in place until such time that Netgear offers an updated firmware that addresses these issues.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes.
quethrosar wrote:any update on this ? i have v3.2.9.2. skype and anydesk disconnects every 10 to 15 minutes.
So, my latest modifications to configurations in an attempt to block auto-update and hang on to known-good (at least for me) firmware version v3.1.5.23_1.0.46 is as follows:
Router and Satellite:nvram settings:
auto_upgrade_enable=0
ver_check_enable=0
Router:
blocked sites:
updates1.netgear.comOn the Router via the web UI admin, in Advanced mode, for the Firmware update screen, it now (correctly) shows the Current Version of the firmware as V3.1.5.23. For the Router, for the Status column, it shows "Service Unreacheable" for the Router, and "v3.2.9.2" for the Satellite. The fact that the Satellite can see v3.2.9.2 is a bit of mystery to me, but I'm hoping because I blocked the domains for the upgrades, I'm hoping I've "crippled" the automated upgrade capabilities. I'll know for sure tomorrow morning......
v3.2.9.2 on the RBS should be a problem. ITs the RBR that has the problem. You'd be fine with the RBS where ever it ends up at.
Leave it for now and lets see what NG does for us.
