MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
rcw3
Mar 15, 2020Tutor
Bought the RBR850 a few weeks ago and everything was fine until about a week ago, then I started getting disconnected during large downloads making it very painful to download large files. I also get disconnected continuously (every 10 minutes or so) from WoW. It seems to occur when using ethernet off the Orbi as well. it DOES NOT happen with I plug directly into the DSL modem's ethernet ports.
I was about to return it for a refund when I saw these threads. I might consider waiting for a new firmware update, but it's very disconcerting that the level of testing would allow something this bad that impacts so many users.
- FURRYe38Mar 15, 2020Guru - Experienced User
rcw3 wrote:Bought the RBR850 a few weeks ago and everything was fine until about a week ago, then I started getting disconnected during large downloads making it very painful to download large files. I also get disconnected continuously (every 10 minutes or so) from WoW. It seems to occur when using ethernet off the Orbi as well. it DOES NOT happen with I plug directly into the DSL modem's ethernet ports.
- quethrosarMar 15, 2020Star
i have SB8200 modem.
V3.2.9.2_1.2.4
Have you powered OFF the isp modem and RBR for 1 minute then back on?
quethrosar wrote:i have SB8200 modem.
V3.2.9.2_1.2.4
- rcw3Mar 16, 2020Tutor
v.3.2.10.11
Actiontec 3200
Windstream
FURRYe38 wrote:What Firmware is currently loaded?
