MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
Mar 15, 2020Guru - Experienced User
rcw3 wrote:Bought the RBR850 a few weeks ago and everything was fine until about a week ago, then I started getting disconnected during large downloads making it very painful to download large files. I also get disconnected continuously (every 10 minutes or so) from WoW. It seems to occur when using ethernet off the Orbi as well. it DOES NOT happen with I plug directly into the DSL modem's ethernet ports.
I was about to return it for a refund when I saw these threads. I might consider waiting for a new firmware update, but it's very disconcerting that the level of testing would allow something this bad that impacts so many users.
quethrosar
Mar 15, 2020Star
i have SB8200 modem.
V3.2.9.2_1.2.4
- FURRYe38Mar 15, 2020Guru - Experienced User
Have you powered OFF the isp modem and RBR for 1 minute then back on?
quethrosar wrote:i have SB8200 modem.
V3.2.9.2_1.2.4
- DBVMar 16, 2020Apprentice
Netgear needs to fix this issue today! Spending way too much time trying to fix and sounds like many others are too and to think these are the ones that know about this forum, so their are many others that have no clue what is even wrong.
Get it right NG or provide refunds to everyone that has an issue, so I can spend my money on something else. $700 is too much to spend for such a lack of response and quick fix!
