MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
DPirkl
Mar 16, 2020Tutor
I reverted FW to 3.2.8.5 via NG Tech Support. Still having the same issue of dropping. I saw that there is an earlier version 3.2.7.2 but I went to the 3.1.5.23 and put that FW in the Router only (RBS is still on 3.2.8.5). I it seems to work. did the site blocking as suggested. My question is does the 3.2.7.2 also have the issue and that is why everyone is jumping down to 3.1.5.23?
Thanks for all the great work from all in this thread. More work happining here than at NG!
Mar 16, 2020Guru - Experienced User
Something with v10.11 seems to have caused prior versions even after manually downloading and installing them to be broke. If users came up thru the versions before v10.11 was released, this issue wasn't seen or a problem. Or wasn't reported or posted about back then if it was a problem.
- DBVMar 16, 2020Apprentice
Anyone hear an update from Netgear or they just doing nothing for people that purchsed their most expensive router. Really poor support from them.
If it was not been for the people on this community, most would be lost. :)
- FURRYe38Mar 16, 2020Guru - Experienced User
Nothings as of yet. NG is working on it. There maybe some delay due to CD19 virus. Business are pushing people to work from home so this may cuase delay. NG is aware of things. No time frame.
