MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
DPirkl
Mar 17, 2020Tutor
How do you "Check your CTS and RTS values, if the are at 64, you might want to set them to 2347. If things are working at 64, leave it." I can connect to the router and login in but I cannot find where to check these settings.
thanks
- FURRYe38Mar 17, 2020Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
