MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
Wombatmatty
Mar 18, 2020Guide
Weirdly... my older Orbi with firmware from July 2019 (no more recent update being pushed) also started developing issues after I went back to it. So if nothing got updated on that one, is it possible there might be some kind of malware? I know these firmware updates are being pushed because of vulnerabilities. Similarly, system resets on that device correct the issue... for a short time. But otherwise, everything on that older Orbi was exactly as it has been for the past 2+ years. Gets ya wondering, right? Because why would an older system on old firmware develop the same / similar symptoms?
Good for thought.
Good for thought.
bluegoose987
Mar 18, 2020Star
Depends if it is something that is common to all platforms a'la NTP breaking which is around when most of these issues seem to be popping up. I'm just using that as an example but if it is a feature common to all NG's firmware then it could affect all models. My older unit did indeed update it's firmware which broke a number of things but after reverting back I still couldn't get all my devices connected until I changed that NTP setting on my older unit.
- cruisencodeMar 18, 2020Apprentice
I just checked my NTP settings and the time on the router and everything looked fine. Plus, this issue didn't start until 3/9 when the new firmware was pushed. It doesn't look like this is the cause of my issues.
Thanks for keeping the ideas flowing though.
- bluegoose987Mar 18, 2020Star
Like I said, grasping at straws...
Very welcome though.
- warpdagMar 18, 2020Apprentice
Grasping at straws... or debugging for free :)
