MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
RafS
Mar 18, 2020Apprentice
This was just posted on another thread in this forum by a mod:
Hi Orbi Community!
We have identified the root cause of the issue and fix will be available. Please do not block Orbi update servers so you can receive the fix. We will provide update once affix is on server.
Blanca
Community Team
Chivvalry
Mar 18, 2020Star
Yeah... I'll unblock the updates when I hear someone tell me it finally works as expected. Who's the sacrifice?
RafS wrote:This was just posted on another thread in this forum by a mod:
Hi Orbi Community!
Blanca
Community Team
- RafSMar 18, 2020Apprentice
I can't do anything since I'm essential services and stuck at work for 14 hours all week.. Hopefully by the time the weekend comes, all will be worked out. I really need my cameras to work while I'm at work all day..
- ChivvalryMar 18, 2020Star
Fix isnt even up yet so you got time... I do hope this works correctly. They lost a LOT of credibility and respect with this firmware debacle.
- FURRYe38Mar 18, 2020Guru - Experienced User
Well I would keep v3.1 loaded as it seems to work to keep your system running. Keep an eye on the forums for any updates on new FW that maybe coming soon. Or contact the forum moderator to give you notice on when the FW is pushed, then unblock the update servers. I'd even ask them if they can send you the FW file instead. Worth asking.
RafS wrote:I can't do anything since I'm essential services and stuck at work for 14 hours all week.. Hopefully by the time the weekend comes, all will be worked out. I really need my cameras to work while I'm at work all day..
Thanks, I might actually send them a message and ask. Like you said, it's worth a try. I don't have a choice at this point with work the way it is but I do need the system to work while I'm away.
- d1mmyMar 18, 2020Apprentice
I volunteer as tribute! I've been dealing with the issues again anyway since getting re-upgraded overnight after my initial downgrade attempt a while back. Once it's available, I'll install and report back.
Chivvalry wrote:Yeah... I'll unblock the updates when I hear someone tell me it finally works as expected. Who's the sacrifice?
Hi Orbi Community!
Blanca
Community Team
