MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
Blanca_O
Mar 18, 2020NETGEAR Employee Retired
Hi Orbi Community!
We have identified the root cause of the issue and the fix has been uploaded to our update server. No need to do anything as this will be auto pushed for users who are using RBK852/RBK853S. If anyone has disconnection issues after the next 24 hours, please let us know.
Blanca
Community Team
MeGrimlock
Mar 18, 2020Apprentice
I'm only seeing 3.2.9.2 as the auto downloaded FW?
Blanca_O wrote:Hi Orbi Community!
Blanca
Community Team
- warpdagMar 18, 2020Apprentice“No New Firmware Available“
- FURRYe38Mar 18, 2020Guru - Experienced User
It may not appear as something available to update. "No need to do anything as this will be auto pushed for users who are using RBK852/RBK853S."
This will be pushed by NG when they trigger this.
For those who have blocked the update servers, you'll need to unblock them to be sure your RBR gets the push.
It's not push, it's more like fetch, despite what they say (happy to share wiresharks, I was one of the ones who helped others block the NG servers). Either the firmware is available for fetch/pull by the router, or it's not. It's not.
- FURRYe38Mar 21, 2020Guru - Experienced User
Were you able to get your system re-updated?
MeGrimlock wrote:I'm only seeing 3.2.9.2 as the auto downloaded FW?
- migstaMar 21, 2020ApprenticeOrbi AX is just garbage. No connection to any outdoor cameras, indoor Arlo is horrible and there is no outdoor strength on these things. Tried all settings for WiFi Chanel’s and RT and CT settings but nothing. Time to sell this piece of garbage.
- WombatmattyMar 21, 2020Guidemigsta
I have an earlier post that references the CTS RTS. I had the same problem and for some reason had to significantly lower my figures. My previous Orbi was set to 2347 and worked fine. That setting wasn’t working on the new system. The default of 64 was better, but not that great. Setting the number to 25 cleared up most of my disconnect issues, but not sure why it had to be so since 2347 works just fine on my old system. - wase471111Mar 22, 2020Apprentice
thanks for that help ful post! - migstaMar 22, 2020ApprenticeIt’s frustrating. There is no answer in sight. Asus, Orbi AC and Nest WiFi no issues with these cameras but Orbi AX refuses to work. I have tried every setting but the cameras will not connect to it. I might get one at times but it loses it within seconds or minutes and never comes back. And, the Arlo Baby camera is simply unwatchable with Orbi AX due to constant pixelating. I notice in the app to that sometimes the satellites drop and the app can’t see devices. In general, speeds are great in house and it works save with the cameras. I have reset everything, including to factory defaults, but nothing works.
- ErnestTheGreatMar 22, 2020NETGEAR Employee Retired
Have you tried disabling the AX feature on RBR850 to see if the issue goes away with the cameras? A lot of these issues with AX routers occur due to developers of the wireless clients, cameras, IoT devices and etc. are lagging in keeping up with technology updates. Most of the issues with Nest Cams, Ring Doorbell, Alexa, Arlo, etc. can be resolved by having those clients updated. Theses issues you are seeing are most likely related to the client devices having issues with one or more new features introduced in the 802.11AX wifi standard. We all had the same issues before when 802.11N and 802.11AC standards first came around it took a while for end-user client manufacturers to catch up to the router manufacturers.
If you are having issues with getting the cameras connected to Orbi AX try the following. Disable AX feature on your Orbi AX and let the cameras connect once connected enable the AX again and see if you have issues with connectivity. Also, make sure that your client devices are fully up to date with software and firmware. - FURRYe38Mar 22, 2020Guru - Experienced User
My two NEST controllers and 3 D-Link cameras are working well with Orbi AX. Though my cameras are not outdoors.
- TURBOGUARDMar 22, 2020TutorI have 3 Nest cameras, 1 indoor and 2 outdoor. All working on latest FW
- migstaMar 22, 2020ApprenticeThat’s great. Mine doesn’t work but works great on Nest WiFi. Overall way more stable with Nest and the app is legions ahead of Orbi app. Guess it’s time to sell the RBK853 while it has some value.
- McLongMar 22, 2020Luminary
Glad you found a solution that works. I seriously considered the nest but have used netgear for years and wanted AX.
- RafSMar 23, 2020Apprentice
One issue I found with this firmware that I didn't have with previous firmwares is that is doesn't reserve static IP addresses that I assigned to devices and hands them out in order. When the device that the static IP address was assigned to "asks" for it, it does get it, but the other device, that got it originally, never gets a new one, and stays off the network. A simple reboot does not solve the issue. The only way to figure out what didn't get one is go through the list and see what's not showing up and then reboot that particular device. Never had to do that before this firmware.
- FURRYe38Mar 23, 2020Guru - Experienced User
Please make a new post about issues your seeing. This thread is mostly for the frequenct disconnects seen during the time frame NG was having problems with there cloud services. Which has been resolved.
Thank you.
RafS wrote:One issue I found with this firmware that I didn't have with previous firmwares is that is doesn't reserve static IP addresses that I assigned to devices and hands them out in order. When the device that the static IP address was assigned to "asks" for it, it does get it, but the other device, that got it originally, never gets a new one, and stays off the network. A simple reboot does not solve the issue. The only way to figure out what didn't get one is go through the list and see what's not showing up and then reboot that particular device. Never had to do that before this firmware.
I thought this would be why some people are still having disconnects and why I posted it in here. If two devices are sharing an IP address, they would obviously continue to disconnect from the network. The two devices shared an IP address and while that's not supposed to happen, that's exactly what did happen and it's what may be happening to folks who may still be experiencing issues, like with the cameras.
Most of the disconnects were when the NG cloud services became problematic. Most of the disconnects should be resolved. Also changing of the CTS and RTS values can held as well. If there is a problem with IP addressing, I would make a new thread about it and lets discuss it there. Also know that there are differences between STATIC and Reservation IP addresses.
RafS wrote:I thought this would be why some people are still having disconnects and why I posted it in here. If two devices are sharing an IP address, they would obviously continue to disconnect from the network. The two devices shared an IP address and while that's not supposed to happen, that's exactly what did happen and it's what may be happening to folks who may still be experiencing issues, like with the cameras.
- dglsmcd_USMCMar 23, 2020Luminary
All of us have put a lot of time and effort trying to resolve our unique network issues (no firmware is an answer to all people and all issues) but I did try reverting to 3.2.9.2 (my RBK 852 is in AP mode). The router and satellite indicated an update available (3.2.10.11) and when I clicked the update button both units upgraded without a hitch. I did a hard reset on both units and setup as a new system using the Orbi app (same SSID and password before the reset and did NOT reload a previous config file). Both 5G and 2.4G wireless channels were set on a channel to avoid interference locally, CTS/RTS set to 2347, 20/40 coexistence deselected on the 2.4G wireless channel. My previous issue with 3.2.9.2 (2.4GHz and 5GHz wireless channels) and my PS4 Pro connectivity has vanished. No issues or dropouts experienced to date (now 2 days operative).
- pedroyMar 24, 2020TutorNew firmware posted... this firmware works!
- TURBOGUARDMar 24, 2020Tutor
pedroy wrote:
New firmware posted... this firmware works!What?! Now I'm scared. It's been working soooo well for the past few days 😱
- pedroyMar 24, 2020TutorI’ve been testing it for a week now. I don’t have issues so far...
pedroy wrote:
I’ve been testing it for a week now. I don’t have issues so far...Wait, are you talking about 3.2.10.11? It's not new as of today... You scared me.
- d1mmyMar 24, 2020Apprentice
3.2.10.11_2.1.12 is the same firmware that started this mess. It isn't new. I have seen reports that Netgear claims the issue was "in the cloud" with no additional explanation of how or why that would impact LAN/WiFi performance. I have, to this point, still been having issues. I recently disabled the AX WiFi setting/features, and that may have improved connectivity with my WeMo devices and Pixel 2 XL phone that were seeing regular disconnection issues. Yesterday was particularly bad for my WeMo devices. Before I disabled AX features on my WiFi yesterday, 90% of them had been offline (not connected to WiFi, so nothing to do with Belkin's cloud...not able to connect to my LAN) for hours.
- FURRYe38Mar 24, 2020Guru - Experienced User
v10.11 was reposted on NGs download site I believe last week sometime. So users can have access to actual files again.
https://www.netgear.com/support/product/rbk853.aspx#download
It has been posted on the site however was remove after users complained of having problems. This has since been resolved due to the issues not being related to the actual FW or files that came down from NG. The issues were on there cloud systems which have been fixed.
Users have been posting good operation after NG fixed the issues on there side on 3/19.
For users continuing to have problems after 3/19, please make a new post and we can being troubleshooting the problem to see where it maybe. This thread is getting long and the topic of this thread has been fixed.
TURBOGUARD wrote:
