MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
Mar 19, 2020Guru - Experienced User
Downgrade to v3.2.9.2 then let the system get pushed to v10.11...factory reset then setup from scratch. v10.13T1 is not recommended.
d1mmy wrote:I'm not even getting an updated firmware pushed to me and my devices are still offline. My devices are still on the original, bad, 3.2.10.11_1.2.12. I assume xxx.13T1 may mean it's a test version?
tigerisak wrote:Im on V3.2.10.13_1.2.13T1. But are still having dropouts for Zoom, Aircall, Teams and IPTV. Any suggestions?
adr1974
Mar 19, 2020Aspirant
I'm confused...I thought 3.2.10.11_1.2.12 was the update which caused all the issue.
- adr1974Mar 19, 2020Aspirant
i hear you. i updated on mar 9 or so, and system has been pretty stable (with the exception of my voip phone...but i upgraded the phone's firmware yesterday and it's been working fine since). wondering what changed for people if this is the same version which was released ten days ago. wouldn't they change the release number if they changed the code?
- FURRYe38Mar 19, 2020Guru - Experienced User
Fw wasn't changed. It was on there cloud system side.
adr1974 wrote:i hear you. i updated on mar 9 or so, and system has been pretty stable (with the exception of my voip phone...but i upgraded the phone's firmware yesterday and it's been working fine since). wondering what changed for people if this is the same version which was released ten days ago. wouldn't they change the release number if they changed the code?
gotcha -- thanks!
