ssgtweasel
Feb 13, 2021Guide
RBR850-frequently issuing DNS error in browsers then refreshes and proceeds to applicable webpage
Noticing intermittant issues on several of my home PCs, when opening webrower and type in an URL, I'll get an DNS probe error for maybe 2secs then automatically will open the intended webpage Happen...
Feb 13, 2021Guru - Experienced User
- ssgtweaselFeb 13, 2021GuideOk thanks but
It’s dated oct 2020 and not real resolution unless I missed it
I don’t enter to manually set google dns in each device- Mikey94025Feb 13, 2021Hero
Unfortunately the issue still exists and not solved by the latest Orbi AX firmware for the subset of customers impacted by this bug. Follow the main thread if you want to watch for any new progress.
- DNS_PROBE_FAILMar 08, 2021Luminary
Yes, this is a well documented issue with Netgear Orbi AX systems but they're not fixing it.
