ssgtweasel
Feb 13, 2021Guide
RBR850-frequently issuing DNS error in browsers then refreshes and proceeds to applicable webpage
Noticing intermittant issues on several of my home PCs, when opening webrower and type in an URL, I'll get an DNS probe error for maybe 2secs then automatically will open the intended webpage Happen...
Mar 25, 2021Guru - Experienced User
I agree, would be more transparent and helpful to users to have a known list if issues. I believe that most 1st level support doesn't have more details on the issues at hand. There only there to help solve problems. I presume they don't get any back ground information from deeper sources. NG doeesn't seem to communicate or follow some better practices. Been like this for a while. And with what all happened last year, things were delayed as well so fixes that are on the table, may show up later than expected.
NG is aware. Heres to hoping for something soon.
ed-win
Apr 13, 2021Guide
I solved my issues by buying three ASUS ZenWiFi AX (XT8). Work great and have a lot of configuration options I was missing in the Netgear Orbi. Will not be buying Netgear again.
Good luck to the rest of you still on the Orbi AX.
