tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
tantrum
Also not having the issue with (or any issue with) the devices losing connectivity from the network or such, as I'd seen in a couple of other threads. Everything stays happily connected and other concurrent requests continue streaming uninterrupted, just individual and intermittent host lookups that fail.
kildare
Jun 06, 2020Luminary
If I were you I'd do a settings backup and then a full reset.
After that I'd restore the settings and see if DNS lookup problems come back.
AFAIK no others have posted this problem before.
- tantrumJun 06, 2020Apprentice
Routers with Circle have reported the same issues, but this router doesn't have that yet. The same thing Circle is activating may be getting leverated here though too.
Although I haven't yet seen users report it with this router, so perhaps it will have to come to that.
The telnet debug option isn't available on this router either currently, or else I may be able to have a little more control (e.g. restart dnsmasq etc.).
- gb777Jul 31, 2020Apprentice
- tantrumJul 31, 2020Apprentice
Yes, Retired_Member pointed that out some weeks ago. I've used it now to get telnet access, thanks.
It hasn't yet helped me to fix dnsmasq's (configuration?) shortcomings though. Since the past few weeks the issues haven't been recurring so much on the apple tv's (and I don't think I hard coded their dns entries), and I did hard code the entries on my computers so don't notice it there.
I'll have to get back to retest it soon; I've been hellaciously busy since November, and it's not the only issue this mesh router has that needs to be sorted out.
