tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
kildare
Jun 06, 2020Luminary
If I were you I'd do a settings backup and then a full reset.
After that I'd restore the settings and see if DNS lookup problems come back.
AFAIK no others have posted this problem before.
tantrum
Jun 06, 2020Apprentice
Routers with Circle have reported the same issues, but this router doesn't have that yet. The same thing Circle is activating may be getting leverated here though too.
Although I haven't yet seen users report it with this router, so perhaps it will have to come to that.
The telnet debug option isn't available on this router either currently, or else I may be able to have a little more control (e.g. restart dnsmasq etc.).
