tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
Jun 06, 2020Guru - Experienced User
I also have not see this aswell. Would point to either a configuration issue or symtopm upstream. A factory reset should be performed on the RBR if one hasn't been done since last FW update. Revert back to v11.2 as well to see if the problem follows..
Possible issue would be at your ISP services, ISP DNS or ISP Modem. Seen others with your particular modem having problems with Orbi systems historically. Though its just a modem only.
