tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
tantrum
Jun 10, 2020Apprentice
Retired_Member Are you running a beta / early firmware for the router?
The telnet option doesn't display in the debug form for me, and even if I try and force it, either by using the browser dev tools and forcing the css to show the form block, or manually issuing the form post with the correct parameters using a curl request, the option doesn't stick on the debug page and the router doesn't respond when I try to telnet (port 23) to it.
Anonymous
Jun 10, 2020
tantrum wrote:Retired_Member Are you running a beta / early firmware for the router?
I am on current firmware V3.2.15.25_1.3.15 and telnet has been enabled by default on my router and sats.
Maybe it has something to do with my account being enrolled for betatesting? Maybe some other betatesters can answere this?
Reg
Arild
- AnonymousJun 10, 2020
Reg
Arild
Telnet stoped working after I did a factory reset. But got it up again using this utlity
- FURRYe38Jun 10, 2020Guru - Experienced User
I believe telnet was removed in some recent FW updates. Even for beta testers. :smileyfrustrated:
Glad the work around helps.
- arlomikeJul 29, 2020ApprenticeI too have experienced DNS timeouts...not frequent but enough to notice its a resolver issue. The routers recursive server is buggy. Wonder if I can telnet in and install powerdns recursive instead. It sucks that the we can't set what DNS servers DHCP hands out. I'm not about to manually set DNS servers on all my devices.
- amenicSep 19, 2020Apprentice
How do you disable it after enabling it? I notice that it's available outside network (WAN).
- AnonymousSep 20, 2020
I guess you could set the
telnetd_enable=1 to 0 and do a nvram commit and reboot
