tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
arlomike
Jul 29, 2020Apprentice
I too have experienced DNS timeouts...not frequent but enough to notice its a resolver issue. The routers recursive server is buggy. Wonder if I can telnet in and install powerdns recursive instead. It sucks that the we can't set what DNS servers DHCP hands out. I'm not about to manually set DNS servers on all my devices.
Jul 30, 2020Guru - Experienced User
What version of FW do you have loaded?
I'm using v32 and have no seen any DNS issues thus far. Using Auto DNS detect on the RBR which sees my ISP DNS.
You might try setting manual DNS addresses to something else like 1.1.1.1 and 9.9.9.9 on the RBR to see if this maybe a ISP DNS issue. Not th first time ISP DNS has causes problems.
