tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
gb777
Jul 31, 2020Apprentice
The telnet debug option isn't available on this router either currently, or else I may be able to have a little more control (e.g. restart dnsmasq etc.).
tantrum
Yes, Retired_Member pointed that out some weeks ago. I've used it now to get telnet access, thanks.
It hasn't yet helped me to fix dnsmasq's (configuration?) shortcomings though. Since the past few weeks the issues haven't been recurring so much on the apple tv's (and I don't think I hard coded their dns entries), and I did hard code the entries on my computers so don't notice it there.
I'll have to get back to retest it soon; I've been hellaciously busy since November, and it's not the only issue this mesh router has that needs to be sorted out.
