tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
arlomike
Jul 30, 2020Apprentice
I'm on .25 version. My RBR is set to use quad 1 and quad 8 already. This is something that has not happened or noticed before i switched to Orbi. The orbi is definitely suspect.
Jul 31, 2020Guru - Experienced User
I would contact NG support and ask them for help and information about this. Possible some thing in FW that may be faulty with particular ISP services. Which I may not be seeing with my ISP.
- amenicSep 18, 2020Apprentice
Maybe I should buy another router (and return it) just to get the amazing 90 day support for a product that isn't working properly and then I can contact NG for support to actually (and properly) resolve this?
