tantrum
Jun 06, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
Retired_Member
Sep 25, 2020Yes I could do that, but I see there is a big risk for people to brick their Orbi-routers when not used to work on unix-systems.
And I would not be responsible for this, as my guide could may be missread or badly written by me :)
I have reported the bug found in dnsmasq and I hope Netgear will work on this and make a patch for everyone to install.
scng
Oct 19, 2020Initiate
Same problem with RBR750.
Retired_Member wrote:Yes I could do that, but I see there is a big risk for people to brick their Orbi-routers when not used to work on unix-systems.
- jj911c2Oct 19, 2020Tutor
I had the same problems w/ my 750 and tried all the troubleshooting steps as well as opening a support case with Netgear. I was unable to fix the issue with DNS.
I ended up just flipping my cable modem (Xfinity) back to router mode and set the Orbi to AP mode. You really don't lose a lot of functionality (I can still see which devices are connected to each satellite in the Orbi application) in AP mode. This fixes the DNS issue as your cable modem takes over this functionality. Strange you have to do this for such a high end system...but the signal strength/wired satellites makes it worth keeping.
