tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
Apr 02, 2021Guru - Experienced User
You can try this:
Been using it and though I have seen a couple of DNS errors here and there, not frequent and seems to help some with this issue. I had not seen this until the time change this past month. Some of this maybe time related as well.
So try it and let us know.
pv_omaha wrote:I have the RBR850 setup and have been dealing with support for a few days now.
My firware is now current at V3.2.17.12_1.4.14
Their solution options which took my 4 people to talk to today to get are:
1. RMA for a refurbished replacement which will not reset the support clock. It will still go off of original purchase date.
2. If the reatiler you purchased from with exchange it, do that.
I really wish I was making this up. I just update my case with a number of community forum links that all state the same issue.
Is anyone haing the issue on my firmware still. I haven't seen it today, but that doesn't mean its fixed.
KasemO
Apr 04, 2021Star
It's not IPV6. It's DNS.
