tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
Mikey94025
Jun 06, 2020Hero
tantrum wrote:Has anybody else been getting these kinds of issues with the DNS proxy? Any solutions that worked for you besides manually configuring all your devices to use another DNS server than the proxy (and/or setting up a replacement DHCP service to do so more easily)?
I do think I've seen this. As I browse websites and click links I've intermittently seen my Windows laptop browser briefly display "cannot connect to site XXX", then redisplay and succeed. The frequency is pretty low, maybe once or twice a day.
I've seen this for the months I've owned my Orbi AX system and it didn't occur with my older Orbi AC system. I'm guessing it's this same DNS proxy issue you're describing because it would explain what I'm seeing. Like you, I've tried switching to Google DNS servers but that did not stop this intermittent lookup. I am not using Armour or Circle and my Orbi router settings are very basic/default.
Thank you for the deep dive and investigating with Netgear.
KickassCaptain
Jul 15, 2021Aspirant
I have the same issue on my AX router RBR 850
- FURRYe38Jul 15, 2021Guru - Experienced User
Please make contact with @Christian_R
KickassCaptain wrote:
I have the same issue on my AX router RBR 850 - amenicJul 29, 2021ApprenticeI finally gave up. Sold the unit so it will be someone else's problem as Netgear could obviously care less.
Bought a new Ubiquity mesh router and it's already way better at the same price point.
I'll never buy another NG router....- FURRYe38Jul 29, 2021Guru - Experienced User
- amenicAug 02, 2021Apprentice
I couldn't help but laugh. One of the first things I notice on the new router (non-Netgear) I notice when browsing options (see screenshot)
This obviously is a problem for others and just a crazy simple solution.... (just turn it off!)
