tantrum
Jun 05, 2020Apprentice
RBR850 frequently issuing DNS REFUSED responses
Had the RBK852 now for just over a month, and have an issue I'll open a support ticket for. Wondered though if others have been experiencing anything similar. Basically and since day 1 after put...
- Jul 29, 2021
Good Luck. This issue is resolved by the beta thats available.
amenic
Jul 29, 2021Apprentice
I finally gave up. Sold the unit so it will be someone else's problem as Netgear could obviously care less.
Bought a new Ubiquity mesh router and it's already way better at the same price point.
I'll never buy another NG router....
Jul 29, 2021Guru - Experienced User
- amenicAug 02, 2021Apprentice
I couldn't help but laugh. One of the first things I notice on the new router (non-Netgear) I notice when browsing options (see screenshot)
This obviously is a problem for others and just a crazy simple solution.... (just turn it off!)
- FURRYe38Aug 02, 2021Guru - Experienced User
Can't see the picture though I presume it's a DNS problem as seen on Orbi AX?
