RickMacca
Dec 07, 2021Aspirant
RBR850 Guest Network no internet
I have an RBR850 with one satellite. The RBR850 connects to the ISP modem/router through a powerline device. The internet works perfectly on all connected devices, both on RBR850 and satellite. Both ...
Dec 07, 2021Guru - Experienced User
Turn OFF the RBS.
Does guest network devices connected at the RBR get internet services?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Router build in here? IF so, Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
RickMacca wrote:
I have an RBR850 with one satellite. The RBR850 connects to the ISP modem/router through a powerline device. The internet works perfectly on all connected devices, both on RBR850 and satellite. Both are running the latest updates.
However, when the guest network is enabled, devices can connect to it, but do not have internet. Any advice appreciated.
Rick
- RickMaccaDec 07, 2021Aspirant
Thanks for the helpful replies. Firstly, the I turned off the wifi on the iSP modem some time ago, when I first set up the Orbi. So that aspect should not be an issue.
As suggested, Access Control seems to be where the issue lies. I noticed that both the Guest Network, and also the device I was trying to connect, were both blocked. So I allowed both, and only after rebooting the router, I was able to get internet on the guest device.
However I don't think it should be necessary to go into the router admin settings and "allow" a guest device to connect. I would expect any guest to whom the password has been provided, should be able to get an internet connection.
Anyway, I have the feeling that the guest network connection may be unreliable, so I will test it over the next few days.
Thanks for all the assistance.
- CrimpOnDec 07, 2021Guru - Experienced User
Is "blocked" another word for "not enabled"? If the Guest network is not enabled, then of course no device can connect successfully.
On my (old, but faithful) Orbi, I have the parameters for Guest WiFi configured all the time, but only enable the guest WiFi for specific tests.
- RickMaccaDec 08, 2021Aspirant
"Blocked" and "not-enabled" are different. The guest network is enabled (the guest wifi network can be seen and devices can connect, but no internet.
By "blocked" I am referring to the access control for individual devices. So what I was explaining is that devices can connect to the guest network, but they cannot get an internet connection until each indivual device is "allowed" in the access control.
After finally figuring out how to allow guest devices to get internet, my point was that I don't think it should be necessary to go into the Orbi admin and "allow" devices invited to connect to the guest network. When a guest wants internet connection, the password should be all that is required. I would have thought that facility was part of the reason to have a guest network.
Following this same point, I was wondering if there is a separate setting for the guest network to "allow all new devices to connect"? This setting is in the access control, but I understand applies to entire network, not only guest network.
