RickMacca
Dec 07, 2021Aspirant
RBR850 Guest Network no internet
I have an RBR850 with one satellite. The RBR850 connects to the ISP modem/router through a powerline device. The internet works perfectly on all connected devices, both on RBR850 and satellite. Both ...
RickMacca
Thanks for the helpful replies. Firstly, the I turned off the wifi on the iSP modem some time ago, when I first set up the Orbi. So that aspect should not be an issue.
As suggested, Access Control seems to be where the issue lies. I noticed that both the Guest Network, and also the device I was trying to connect, were both blocked. So I allowed both, and only after rebooting the router, I was able to get internet on the guest device.
However I don't think it should be necessary to go into the router admin settings and "allow" a guest device to connect. I would expect any guest to whom the password has been provided, should be able to get an internet connection.
Anyway, I have the feeling that the guest network connection may be unreliable, so I will test it over the next few days.
Thanks for all the assistance.
CrimpOn
Dec 07, 2021Guru - Experienced User
Is "blocked" another word for "not enabled"? If the Guest network is not enabled, then of course no device can connect successfully.
On my (old, but faithful) Orbi, I have the parameters for Guest WiFi configured all the time, but only enable the guest WiFi for specific tests.
- RickMaccaDec 08, 2021Aspirant
"Blocked" and "not-enabled" are different. The guest network is enabled (the guest wifi network can be seen and devices can connect, but no internet.
By "blocked" I am referring to the access control for individual devices. So what I was explaining is that devices can connect to the guest network, but they cannot get an internet connection until each indivual device is "allowed" in the access control.
After finally figuring out how to allow guest devices to get internet, my point was that I don't think it should be necessary to go into the Orbi admin and "allow" devices invited to connect to the guest network. When a guest wants internet connection, the password should be all that is required. I would have thought that facility was part of the reason to have a guest network.
Following this same point, I was wondering if there is a separate setting for the guest network to "allow all new devices to connect"? This setting is in the access control, but I understand applies to entire network, not only guest network.
- CrimpOnDec 08, 2021Guru - Experienced User
Thanks for explaining. I agree completely that the Access Control setting seems absurd when applied to the Guest WiFi. (Although the primary network is a similar situation. If a device can supply the password to the primary WiFi, what is the point in having an Access Control setting to deny a connection until 'approved' by the owner?)
Yet another reason I am happy not to have enabled Access Control.
Yes, agree. I think while I have guests visiting, I will disable the Access Control.
As a development change, I recommend a setting which allows Access Control to be disabled for the guest network, while retaining access control to the primary network. In this way, if someone manages unauthorised access to the guest network, they will not have access to the primary network.
