ScottD67
Jan 12, 2020Star
RBR850 Guest Wifi in AP mode (w/FiOS router)
Based on my searches it seems others have been able to get guest wifi networks on the Orbi working when the unit is in AP mode (vs router mode). I'm using the RBK852 and can't seem to get my gues...
Bandito
Jan 12, 2020Luminary
It looks like someone else is running into the same issue. See:
It sounds like There may be a problem with the Orbi's in AP mode. I'd give Netgear a call and see what they can determine.
Just curious, but is there a reason you want/need to keep your FIOS router as the active router for the network? The Netgear routing seems to be pretty robust and gives you more info via the router's web page.
ScottD67
Jan 12, 2020Star
Thanks.
I'll probably get rid of my FiOS router in a few months. Right now I'm reworking my home network to get off the FiOS STBs. Once that happens and I will most likely move over to the Orbi.
