davidlan
Jul 02, 2021Follower
RBR850 How to force iphone 11 Pro connect to 2.4Mhz and not 5.0?
I have an iphone 11 Pro that has to be on the 2.4Mhz band to set up a security camera. I have attempted multiple things to get it to work. I have read previous posts and attempted those suggestions b...
Jul 02, 2021Guru - Experienced User
So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was. Turn OFF the RBS during this process to ensure your mobile device connects only to the RBR on 2.4Ghz.
