GFW
May 17, 2021Aspirant
RBR850 How to force iphone X connect to 2.4Mhz and not 5.0?
I have an iphone 10 that has to be on the 2.4Mhz band to set up a security camera. I have attempted multiple things to get it to work. I have read previous posts and attempted those suggestions but ...
Christopher128
In the event that you attempt to utilize your cell phone which is associated naturally to 5 GHz to oversee and arrange one of the keen devices which is associated with 2.4 GHz band, that probably won't work much of the time.
CrimpOn
May 17, 2021Guru - Experienced User
My experience is that once a device has been connected to WiFi, the smartphone running the app that controls the device can be on any WiFi band, and often not on WiFi at all. (Smart plugs, smart bulbs, thermostats, cameras, etc.)
