GFW
May 17, 2021Aspirant
RBR850 How to force iphone X connect to 2.4Mhz and not 5.0?
I have an iphone 10 that has to be on the 2.4Mhz band to set up a security camera. I have attempted multiple things to get it to work. I have read previous posts and attempted those suggestions but ...
May 25, 2021Guru - Experienced User
Try changing the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was. Under Advanced Tab/Advanced Settings/Wireless Settings
GFW wrote:I have an iphone 10 that has to be on the 2.4Mhz band to set up a security camera. I have attempted multiple things to get it to work. I have read previous posts and attempted those suggestions but the phone still joins 5.0. I would appreciate any advice as I have spent 3-4 hours attempting a solution.
