GFW
May 17, 2021Aspirant
RBR850 How to force iphone X connect to 2.4Mhz and not 5.0?
I have an iphone 10 that has to be on the 2.4Mhz band to set up a security camera. I have attempted multiple things to get it to work. I have read previous posts and attempted those suggestions but ...
titaniumrx8
Jun 02, 2021Apprentice
The wyze app and camera don't care that your phone is on 5g. The V2 cam only has 2.4g and that's where it will connect.
Your problem might be that your SSID or password have changed and the wyze app doesn't have a facility for changing the cam's wifi credentials. In the wyze app, delete the camera, power cycle the cam and start a fresh device add (+ sign). Yuu'll be connected in under 2 minutes.
It's a whole other story for some other iot devices that require your phone to connect directly to the device to set it up but the wyze installation is very straightforward.
