hansgmailcom's avatar
hansgmailcom
RBR850 in AP mode and 4 RBS850 hardwired via Router.
I have an RBR850 in AP mode and four RBS850 to create an wifi 6 mesh network. De RBS850/RBR850 are all hardwired (port one) via a switch (Ubiquity). Firmware: V3.2.17.12_1.4.14 on all of the devices....
  • hansgmailcom's avatar
    hansgmailcom
    Mar 26, 2021
    Thank you for your reply.  Looks like the update within the network of Orbi will only work if the backhaul is connected wireless. The moment I disconnected the cables on all the units it performed the updates. I did bring them a bit closer to the RBR to make sure the connection was stable. They are all working now with an updated setting. I assumed that the update of all the units from the RBR would be better in de wired mode, so I did not even consider going back to wireless.  It is a bit of a pain to do it this way. I have the units across my property and not only in the house but also in the outbuildings. They cover a total area of about 1000 m2. (almost 11.000 ft2.  Wireless backhaul does work but is a bit unreliable on the units which are the furthest away, so I switched to wired. Again, thank you for your reply.  H
