hansgmailcom
Mar 16, 2021Aspirant
RBR850 in AP mode and 4 RBS850 hardwired via Router.
I have an RBR850 in AP mode and four RBS850 to create an wifi 6 mesh network. De RBS850/RBR850 are all hardwired (port one) via a switch (Ubiquity). Firmware: V3.2.17.12_1.4.14 on all of the devices....
- Mar 26, 2021
Thank you for your reply. Looks like the update within the network of Orbi will only work if the backhaul is connected wireless. The moment I disconnected the cables on all the units it performed the updates. I did bring them a bit closer to the RBR to make sure the connection was stable. They are all working now with an updated setting. I assumed that the update of all the units from the RBR would be better in de wired mode, so I did not even consider going back to wireless. It is a bit of a pain to do it this way. I have the units across my property and not only in the house but also in the outbuildings. They cover a total area of about 1000 m2. (almost 11.000 ft2. Wireless backhaul does work but is a bit unreliable on the units which are the furthest away, so I switched to wired. Again, thank you for your reply. H
Mar 16, 2021Guru - Experienced User
hansgmailcom wrote:I have an RBR850 in AP mode and four RBS850 to create an wifi 6 mesh network. De RBS850/RBR850 are all hardwired (port one) via a switch (Ubiquity). Firmware: V3.2.17.12_1.4.14 on all of the devices. I can edit all devices via the webinterface so they are visable. Satellites are visable as "wired" in the webinterface of the RBR850. It indicates in basic mode there is internet. It shows the satellites and mentions 43 devices on the network. In the advanced mode it indicates it has not network when I ask to check for new version for all units.
The problem: When I change a setting on the RBR850, like changing a security option is will not update the satillites. You cannot change the settings on each satellite via their own webinterface. You can only view them.
How long are you waiting before checking the RBSs web pages for any security changes?
What security setting are you changing?
The question: How do I update the RBS850 satillites to the settings of the RBR850? Can you force it somehow?
After applying the change the RBS should update, however try powering 1 RBS OFF for 15 seconds then back on. GIve it a few minutes then check the 1 RBS web page to see if it updated.
Has a factory reset and setup from scratch been performed since last update?
What is the distance between the router and satellite(s)?
hansgmailcom
Mar 26, 2021Aspirant
- FURRYe38Mar 26, 2021Guru - Experienced User
Update? What update are you referring too?
Didn't you say FW was udpated on all units already?
- hansgmailcomMar 26, 2021Aspirant
Sorry if I was not clear in my mail. I meant the update of the WIFI settings to all 4 of the RBS 850's as I change them in the RBR850 via the web-interface. The problem started when all the units were wired and one of the RBS850 did not show encryption anymore on the common WIFI network while all the other units including the RBR850 showed encryption. I assumed I did something wrong on the RBR850 so I changed this one to none encryption and waited until all the RBS850 showed this. Nothing happened, not even after one day. No syncing of settings from the RBR850 to the satellite RBS850 units. Only when I performed the activity as described (backhaul wireless and all RBS850 close to the RBR850) did it change the settings of all the satellites to reflect the once on the RBR850. Hope it is clear now. Thank again. H.
Yes, now that makes sence.
So how do you have the RBS connected when wired?Directly to the back of the RBR or is there any LAN switches in between the RBR and RBS?
