jmmonline
Dec 29, 2021Aspirant
RBR850 interface becomes inaccessible
Now that my very limited support window has expired (considering how expensive this product is), I am still left with an issue that support were unable to resolve during that time, namely that the RB...
CrimpOn
Dec 29, 2021Guru - Experienced User
Truly bizzare. What steps restore either (or both) forms of access?
p.s. As a community forum, none of us are employed by Netgear. The issue of an outstanding open case should be referred to a forum moderator to see if it can be resurrected. Blanca_O
- jmmonlineDec 29, 2021AspirantMany reports of this in other threads. Not confined to RBR850 either. Netgear’s advice was to update firmware by wire, factory reset and set up from scratch. Didn’t work. Netgear need to think of something else or no more of their products for me. These are expensive bits of kit.
- jmmonlineDec 29, 2021AspirantOops didn’t answer your question. Power cycle does the trick for a while as this is all you can do without interface or telnet access enabled.
- CrimpOnDec 29, 2021Guru - Experienced User
Power cycle the router, and both management methods appear, but then (after how long?) they fail.
Is Anywhere Access being done locally from the LAN, or from a remote location?
For local web access, is it accessed (a) by URL (http://orbilogin.net), or (b) by IP address of router?
What is the specific error message the web browser displays?
(happens on more than one browser and more than one computer/laptop/tablet?
I am one of the folks who was annoyed when Netgear decided to remove Remote Access from the Orbi advanced settings. Yes, I understand that exposing port 443 to the internet is a potential vulnerability (especially if the Orbi password is not very complicated) and the web server bundled with OpenWRT may have unpatched vulnerabilities. But, that's sort of the user's option, isn't it?
I find the app to be almost useless, so I enabled OpenVPN on my router(s) and use it to management them remotely. Not trivial to set up, but it provides access to the full web interface and every device on the LAN.
