miller1975
Feb 19, 2025Tutor
RBR850 Internet disconections
I am assuming this is related to https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Major-Firmware-7-2-6-31-issues/m-p/2380396 I am running in AP mode If I upgrade to 7.2.6.31 m...
Feb 19, 2025Guru - Experienced User
Did you downgrade the RBS first then RBR lastly after applying v.21 FW?
How is the RBR connected to the host router?
What is the brand and model# of the host router the RBR is connected too?
Does the RBR front LED turn PINK or WHITE when this happens?
How is AP mode configured on the RBR? Dynamic or Static. I prefer Static.
Have tested my 850 series many times in AP mode on v.21 with out issues.
miller1975
Feb 20, 2025Tutor
I currently dont have a RBS connected, I also reset the RBR after downgrading
The router is a BT business hub (latest version), bridge mode isnt available with current firmware so I have the RBR running in AP mode
I dont know about the lights because the RBR was in a different room when I was trying to get it working but in the logs its says internet connected/disconected every minute, give or take a second (I presume the time taken to write to the log) its exactly one minute
I have tried both static and dynamic
