miller1975
Feb 19, 2025Tutor
RBR850 Internet disconections
I am assuming this is related to https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Major-Firmware-7-2-6-31-issues/m-p/2380396 I am running in AP mode If I upgrade to 7.2.6.31 m...
miller1975
Feb 19, 2025Tutor
I currently dont have a RBS connected, I also reset the RBR after downgrading
The router is a BT business hub (latest version), bridge mode isnt available with current firmware so I have the RBR running in AP mode
I dont know about the lights because the RBR was in a different room when I was trying to get it working but in the logs its says internet connected/disconected every minute, give or take a second (I presume the time taken to write to the log) its exactly one minute
I have tried both static and dynamic
Feb 20, 2025Guru - Experienced User
Try putting the RBR in router mode and set the IP address it gets from the ISP modem into the modems DMZ or IP-passthru to see if you see disconnections continue.
If the logs are showing disconnect and re-connect, means the ISP modem maybe having problems and the RBR is seeing the result of it. This would show as PINK on the RBR front LED.
