Hineman
May 07, 2020Initiate
RBR850 IP Address Error
Hello everyone. Just got my new 3 pack of the Orbi 6 and when I set up the system today the main router and one satelite set up great, however the 2nd satelite somehow has been assigned a IP address...
- May 07, 2020
Update - Solved by changing the IP address on the router. Did not want to do it but it was quite quick..
Thanks.
Hineman
Thanks.
- FURRYe38May 08, 2020Guru - Experienced User
Glad you got it working. If you have a router front of the RBR, this router maybe using same 192.168.1.1 string as the RBR. You can always change the RBRs IP address to avoid conflicts as well. I use 192.168.0.1.
Enjoy. :smileywink:
