rs8967643
May 25, 2022Tutor
RBR850 iPhone shows as wired and dns failures
I have a RBR850 with two satellites, one of them with wired back haul. When my iPhone is connected to the wired satellite, it shows up as wired (not that I care, but might be part of problem). When wa...
rs8967643
Jun 09, 2022Tutor
Router is connected to a cable modem.
Router firmware is: V4.6.8.2
Satellite one is: V4.6.3.16
Satellite two is the same.
Wired satellite is connected directly to the Orbi router.
When iPhone is connected to the Wired satellite it shows up as wired .
When walking around the house the iPhone appears to fail to get an IP address assigned, so it has plenty of wireless signal but a default IP address so it does not connect to the internet. iPhone is a 13 pro max.
Thanks for any help. I’m going to try using wireless backhaul to see if things connect ok then.
Jun 17, 2022Guru - Experienced User
rs8967643 wrote:
Router is connected to a cable modem.----Which cable modem? model helps.
When iPhone is connected to the Wired satellite it shows up as wired .----that's normal as the router sees it as wired because the satellite is hardwired into the router.
When walking around the house the iPhone appears to fail to get an IP address assigned, so it has plenty of wireless signal but a default IP address so it does not connect to the internet. iPhone is a 13 pro max.----are you using private mac/ip address or icloud relay? if so, disable those at home.
- Retired_MemberJun 28, 2022Had the same issue as you described. Turning off ‘private wifi address’ and ‘limit IP address tracking’ on my iOS devices seems to have fixed the issues for me.
