yetimemphis
Jan 11, 2022Guide
RBR850 IPv6 dropping from Xfinity XB7 hourly
I have searched and searched and cannot find the answer to this issue. I have the RBR853 mesh system. Xfinity gig internet. I have no problem pulling a IPv6 address from the XB7 modem. And the Or...
- Jan 12, 2022
yetimemphis wrote:It seems like using the Orbi in AP mode while the modem is unbridged would be the simplest method. That said, would turning off the routing functions keep the satellites from working or cause other significant losses? I have an Xbox wired to one of the satellites and the modem (XB7) and router (Orbi) are in the center of house. The Xbox is in a corner. It needs the wired connection to a satellite to function well.
I also have a similar setup: XB7 + RBK754 + IPv6 enabled + Brigde mode initially, but I've since switched Orbi to AP mode.
XB7 routing + DNS + DHCP + IPv6 functions are already validated by Comcast within their network/servers and Orbi is a WiFi beast in AP. If Comcast makes any change to their internal servers or XB7 firmware, I don't have to worry about compatibility issue with XB7 not wrking after XB7 firmware update or Orbi firmware update.
This setup will help me avoid any potential compatibility issue between XB7 DNS/DHCP (IPv6) servers and Orbi. I also get FREE parental control, which is disabled with XB7 in Bridge mode. XB7 parental control is a big improvement comparing to paid Orbi parental control.
Unless you're using a specific feature that's only available when Orbi is in Router mode and that feature is missing from XB7 as well, switching to AP mode will simpify your WiFi network with less headache due to compatibility issues as a result of firmware updates.
yetimemphis
Jan 12, 2022Guide
This all sounds reasonable. I noticed the wifi speeds seemed consistently better when I updated to the new FW yesterday. Your reasoning and explanation of the AP mode issue seems to address all my conerns. (IPv6 was there initially but has since fallen off and has not come back --- I'm sure it would if I rebooted the router).
I'll give AP a try this evening (which should be relatively easy to undo if it doesn't work) and report back.
I like the idea of having the parental controls I "pay" for with renting the XB7 but that are unacessible in bridge mode. I don't use a lot of features on the Orbi app, other than speed tests and monitoring connected devices when needed. I don't even use the guest network feature.
Thanks!
SW_
Jan 12, 2022Prodigy
yetimemphis wrote:This all sounds reasonable. I noticed the wifi speeds seemed consistently better when I updated to the new FW yesterday. Your reasoning and explanation of the AP mode issue seems to address all my conerns. (IPv6 was there initially but has since fallen off and has not come back --- I'm sure it would if I rebooted the router).
Thanks!
With XB7 in Router mode, install the xFi App and you'll see big a difference in term of what you're currently missing with XB7 in Brdige Mode, i.e., speed test, devices monitoring, parental control, security reports, etc.
