yetimemphis
Jan 11, 2022Guide
RBR850 IPv6 dropping from Xfinity XB7 hourly
I have searched and searched and cannot find the answer to this issue. I have the RBR853 mesh system. Xfinity gig internet. I have no problem pulling a IPv6 address from the XB7 modem. And the Or...
- Jan 12, 2022
yetimemphis wrote:It seems like using the Orbi in AP mode while the modem is unbridged would be the simplest method. That said, would turning off the routing functions keep the satellites from working or cause other significant losses? I have an Xbox wired to one of the satellites and the modem (XB7) and router (Orbi) are in the center of house. The Xbox is in a corner. It needs the wired connection to a satellite to function well.
I also have a similar setup: XB7 + RBK754 + IPv6 enabled + Brigde mode initially, but I've since switched Orbi to AP mode.
XB7 routing + DNS + DHCP + IPv6 functions are already validated by Comcast within their network/servers and Orbi is a WiFi beast in AP. If Comcast makes any change to their internal servers or XB7 firmware, I don't have to worry about compatibility issue with XB7 not wrking after XB7 firmware update or Orbi firmware update.
This setup will help me avoid any potential compatibility issue between XB7 DNS/DHCP (IPv6) servers and Orbi. I also get FREE parental control, which is disabled with XB7 in Bridge mode. XB7 parental control is a big improvement comparing to paid Orbi parental control.
Unless you're using a specific feature that's only available when Orbi is in Router mode and that feature is missing from XB7 as well, switching to AP mode will simpify your WiFi network with less headache due to compatibility issues as a result of firmware updates.
yetimemphis
Jan 12, 2022Guide
Power cycle complete.
All devices seem to connect fine. IPv6 is available and functioning on all tests. Speeds are screaming fast- all 500 down and above on new laptop/phone/xbox via wireless satellite connections. Hard wired to router getting 1.3 to 1.4G (1.2G plan).
If IPv6 stays functional throughout the evening and tomorrow, I'll consider this a success and the optimal setup for using the rental I was "required" to get (remember, I otherwise would have bought my own had it not been for needing unlimited data) and also getting access to security and parental features built in.
yetimemphis
Jan 12, 2022Guide
Forgot to add... after power cycle, IPv6 NAT went from Moderate to Open. So that resolved itself. No port forwarding or other shennanigans needed.
