MDKUBINSK
May 18, 2024Aspirant
Rbr850. Isp change limited wifi
Changed my ips and wired connections work great. When it comes to wifi only 30% of my devices work. Things just will not connect. Change back to my old isp and everything works 100%. Is there a se...
- May 26, 2024
Fixed. It was a isp issue and not a ng issue. Thanks everyone for your suggestions.
MDKUBINSK
Correct that cable is the only change. No changes to the orbi at all. The isp is not broadcasting.
CrimpOn
May 18, 2024Guru - Experienced User
Perhaps an experiment is in order.
Orbi systems do not require an internet connection to function. True, there is precious little the average person can do with a WiFi router system without an internet connection, but there was a great example on the forum of a medical group that wanted a WiFi system to network their devices in a clinic out in the jungle.
- Remove the internet connection entirely. Reboot the router. Open the Orbi web interface, navigate to Attached Devices, and make a screen shot of the list of satellites and devices that are connected.
- Connect the Ethernet cable to the old ISP and repeat.
- Connect the Ethernet cable to the new ISP and repeat.
Which devices fail to appear when connected to the new ISP?
- MDKUBINSKMay 19, 2024Aspirant
With my old ISP and NO isp all network devices work. When I plug in my new ISP it is mismatch of things that work. For example my android phone will not hook up, no matter where I stand. Same with my printer. One of my Ring cameras work, but all of the others do not work. My Apple TV works, my tablet does not. No rhyme or reason or location (satellite). My laptop which is network wired in works.
Very strange. Do you think the ISP needs to configure something different?
- FURRYe38May 20, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the size of your home? Sq Ft?What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter. - MDKUBINSKMay 26, 2024Aspirant
- FURRYe38May 26, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
