MDKUBINSK
May 18, 2024Aspirant
Rbr850. Isp change limited wifi
Changed my ips and wired connections work great. When it comes to wifi only 30% of my devices work. Things just will not connect. Change back to my old isp and everything works 100%. Is there a se...
- May 26, 2024
Fixed. It was a isp issue and not a ng issue. Thanks everyone for your suggestions.
MDKUBINSK
May 19, 2024Aspirant
With my old ISP and NO isp all network devices work. When I plug in my new ISP it is mismatch of things that work. For example my android phone will not hook up, no matter where I stand. Same with my printer. One of my Ring cameras work, but all of the others do not work. My Apple TV works, my tablet does not. No rhyme or reason or location (satellite). My laptop which is network wired in works.
Very strange. Do you think the ISP needs to configure something different?
MDKUBINSK
May 26, 2024Aspirant
- FURRYe38May 26, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
