Superpapu
Dec 12, 2024Tutor
Rbr850 link aggregation
Hi all Hope someone can tell this. I have the rbk 853. One of the satellites is connected to a más and wish to know if the satellites has link aggregation and if has how to enable it Thanks!
Dec 12, 2024Guru - Experienced User
I don't see anywhere that the satellites support link aggregation.
- SuperpapuDec 12, 2024Tutor
me neither.
Is like the aggregation is only for internet access and not if i wish to connect my nass to the satelite
- plemansDec 12, 2024Guru - Experienced User
That's my understanding as well. That's its wan port aggregation only on those models.
https://kb.netgear.com/000061324/How-do-I-set-up-WAN-aggregation-on-my-Orbi-WiFi-6-System
- KevinLiTDec 12, 2024NETGEAR Moderator
Hello Superpapu,
Welcome to the NETGEAR Community!
I understand that you would like to use link aggregation (LACP) to connect your network attached storage. Your RBR850 supports aggregated WAN link to your Internet Service Provider. WAN aggregation enables multi-gig connectivity providing the full speed of your ISP connection for the connected device. Additionally, port 1 and the WAN port can be setup for WAN aggregation. However, creating link aggregation using LACP on the LAN port for end user devices is not supported at this time.
Best,
Kevin
Community Team
