EricavH22
Jun 28, 2022Guide
RBR850 losing internet connection
As of today, according to the Orbi app, my router keeps losing internet connection. However, the satellites show "green dots", and many of my devices have internet connectivity via WiFi. However, some...
- Jul 01, 2022
Well seems ok. Power is in spec however a bit on the low side.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
I see a few Correct and Un-correctables on the last few channels that could be zero'd.
Something to check cabling, jacks and any splitters.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
ekhalil
Jun 29, 2022Master
What equippment do you have betwen Orbi and your internet source?
