EricavH22
Jun 28, 2022Guide
RBR850 losing internet connection
As of today, according to the Orbi app, my router keeps losing internet connection. However, the satellites show "green dots", and many of my devices have internet connectivity via WiFi. However, some...
- Jul 01, 2022
Well seems ok. Power is in spec however a bit on the low side.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
I see a few Correct and Un-correctables on the last few channels that could be zero'd.
Something to check cabling, jacks and any splitters.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Jun 29, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
EricavH22 wrote:
As of today, according to the Orbi app, my router keeps losing internet connection. However, the satellites show "green dots", and many of my devices have internet connectivity via WiFi. However, some devices are not connecting, so this issue is different from the symptoms I was seeing with the app before ChristineT worked to push the V4.6.8.2 firmware update last month. Power cycled my Netgear modem and the Orbi router, but the issue remains. No outages or issues with my Xfinity 1.3 GB service are reported in my area. Help, please!
EricavH22
Jun 29, 2022Guide
In answer to your many questions...
I have a Netgear CM2050V modem in between the coax line and the Orbi router. The satellites are more than 30 feet away in my 6000 sq.ft. house (with wifi coverage extending beyond that to cover Ring cameras outside). This setup has been in place for over a year, with no issues before the firmware issue from May. The initial setup was done by the BesttBuy geek squad, and I don't believe they did anything special with the settings.
I did power cycle both the modem and router (but not the satellites) yesterday by unplugging for over 10 seconds. I did this after the firmware push as well.
I have no idea if any neighbors are running Orbi systems.
I did update the Orbi app (routine update from Google Play) with no change. One screen shot attached. You can see full wifi-6 connection on my phone, despite the app indicating offline. I also did a speed test yesterday (again while the app said I had no internet), with the results as shown. App shows only 17 of 39 devices connected as of this morning (my phone not included in that list, so I know that list is not accurate).
- ekhalilJun 29, 2022Master
Please login to the web interface (orbilogin.com) >> Go to ADVANCED >> ADVANCED Home >> INTERNET PORT >> CONNECTION STATUS.
What information do you have there when internet is ok, and similarly when the internet is not ok please?
- EricavH22Jun 29, 2022Guideekhalil: After another set of reboots this morning, and confirmation from Comcast that there are no service issues on their end, wifi itself seems more stable. However, according to the app, the router continues to switch between online and offline. My expected 22 devices seem to be connected and stable, and a new speed test run in the app showed slightly increased speeds just now.
Logged in to orbilogin.com just now my Mac (directly connected to the router), and the connection status does not seem to change even though the app shows the router fluctuating between online and offline. Both satellites always appear to be green/online even when the router shows red/offline.
@FURYe38: Router is connected to the modem via a Cat 5E patch cable. Unfortunately, I don't know how to get the requested info on the modem, since I was never given an app to monitor it. Can you help me figure that out? Again, the modem is a Netgear CM2050V for use with Comcast landlines service.
Many thanks to both of you for helping me out!- FURRYe38Jun 29, 2022Guru - Experienced User
Log into the modems web page at 192.168.100.1 with a web browser and collect this information. Look for the Cable Connections page.
I recommend using a CAT6A STP cable between the RBR and CM modem...CAT5E is not rated for 2.5Gb connection rates.
Please post a copy and paste of the modems connection status page.
What CAT# LAN cable are you using between the RBR and Cm modem? CAT6A STP is recommended here.
