andrewalmoayed
Jan 18, 2025Aspirant
RBR850 Low Speeds and Daily Reboots
I have an RBR850 3 unit mesh system, purchased in 2020. We haven’t had issues until the last 6 months. We’re fiber at the house with 1gb service. All tests show over 1gb on the router connected to ISP...
andrewalmoayed
Jan 19, 2025Aspirant
Thank you for the reply. My current firmware is V7.2.6.31_5.0.24. I can try to hardwire one of our satellites. Currently they both are using wireless connections. Are there known issues withV7.2.6.31_5.0.24?
CrimpOn
Jan 19, 2025Guru - Experienced User
andrewalmoayed wrote:
Are there known issues with V7.2.6.31_5.0.24?
There have been enough negative comments that people on the forum recommend against using it.
Might do a forum search and read through some of the conversations.
- andrewalmoayedJan 19, 2025Aspirant
Thank you. I have downgraded to v7.2.6.21. I'll report back if this helps over a few days.
