skyward1
Feb 09, 2020Apprentice
RBR850 magenta light
Hello, I have the Orbi RBK852 (RBR850 router + RBS850 satellite) system with Firmware v3.2.9.2_1.2.4. I have been getting a solid magenta light on the router, but do not seem to have any issues wit...
Feb 10, 2020Guru - Experienced User
Yep. Nothing at the moment. Happens in AP mode as well. I've put in a bug report for this. Just know untill they fix this that you can log in and the front LED will turn Off. Will happen if the connection with the Modem or Main host router is broke then re-established. Doesn't effect internet or wifi operation.
Hopefully NG will get it fixed.
- skyward1Feb 10, 2020Apprentice
Thanks Furry!
I went ahead and submitted a ticket, as well.
- FURRYe38Feb 10, 2020Guru - Experienced User
Awesome. :smileywink:
- skyward1Feb 14, 2020Apprentice
They had me do the magic default reset and told me that if the light problem continued, they would replace the system.
So, I did the reset and it took about 2 hours to get the router and modem happy with each other.
