skyward1
Feb 09, 2020Apprentice
RBR850 magenta light
Hello, I have the Orbi RBK852 (RBR850 router + RBS850 satellite) system with Firmware v3.2.9.2_1.2.4. I have been getting a solid magenta light on the router, but do not seem to have any issues wit...
skyward1
Feb 10, 2020Apprentice
Thanks Furry!
I went ahead and submitted a ticket, as well.
Feb 10, 2020Guru - Experienced User
Awesome. :smileywink:
- skyward1Feb 14, 2020Apprentice
They had me do the magic default reset and told me that if the light problem continued, they would replace the system.
So, I did the reset and it took about 2 hours to get the router and modem happy with each other.
- FURRYe38Feb 14, 2020Guru - Experienced User
Let us know if it happens again. You can test this out by pulling the WAN cable from the back of the RBR for 5 seconds then plug it back in. Front LED should go PINK, then should go back out. If it doesn't, then log back in to the RBRs web page then it should go out. Seems to be a FW issue from what I experience. Should not need a RMA.
Thanks Furry,
I'm just going to leave it alone and see what happens. I feel it's a FW issue, as well, but I am going to follow their request and have it replaced if it happens again. Perhaps a new FW is coming soon?
Sky
