skyward1
Feb 09, 2020Apprentice
RBR850 magenta light
Hello, I have the Orbi RBK852 (RBR850 router + RBS850 satellite) system with Firmware v3.2.9.2_1.2.4. I have been getting a solid magenta light on the router, but do not seem to have any issues wit...
KMDonlon
Feb 17, 2020Virtuoso
Re-installed V3.2.9.2_1.2.4 and it works again, did not do a factory reset. May try from scratch when I have more time.
Feb 17, 2020Guru - Experienced User
ok. :smileywink:
- KMDonlonFeb 19, 2020VirtuosoTried it after setting up from scratch, same issue of service unreachable showing on just the router, I'll just stick with V3.2.9.2_1.2.4 for now and wait for the official firmware update from Netgear.
- FURRYe38Feb 19, 2020Guru - Experienced User
Ok No problem. The Pink LED problem isn't a show stopper anyways.
- KMDonlonFeb 19, 2020VirtuosoAgreed, just odd that's all.... would like to figure out why it is happening but I am unable to think of anything else to try ;)
Not sure. I've asked NG to see if they can post some beta FW for users to try. Will see. You can load the v10 and try it out for a while. Even if the FW update check doesn't work, this would probably be resolve in the next official. Or just keep what ya got loaded for now.
- KMDonlonFeb 19, 2020VirtuosoResponded 👍
