gwbaker
Dec 11, 2020Guide
RBR850 MANY devices missing from attached devices.
I have just noticed that MANY of my attached devices are not showing in the router menu pages. In either the basic or advance menu the attached devices show 11 devices. When I use a port scanning p...
- Dec 18, 2020
Well, 5 days later and I will call this issue fixed.
Moving the RBR to the other end of the basement (was 8 feet away from one of the RBS) has solved my issue. I just don't understand how this would cause the issue. I get that them being to close together could cause client issues, but everything was still connecting. It just was not listed in the attached devices page. Any insight as to why? Not that I need to know, but I would enjoy knowing.
Thanks again for all the help!!!!!!!!!!!!!!!!!
gwbaker
Dec 11, 2020Guide
P.S. Running firmware V3.2.16.22_1.4.9 which reports as current....
- MstrbigDec 11, 2020Master
If the firmware was just updated, it may take 24 hours for the system to stablize.
Try rebooting the router and see if it shows devices correctly.
- gwbakerDec 12, 2020Guide
Unfortunately no, that did not do the trick. I noticed this issue 4 days ago and it has been like this ever since. I have rebooted a number of times and I did so again for good measure.
No change....
- MstrbigDec 12, 2020Master
Are the devices that are missing connected to the router or satellites? If satellites, try resetting the satellites and repairing, one at a time. Also make sure he satellites got updated to the new firmware as well.
