gwbaker
Dec 11, 2020Guide
RBR850 MANY devices missing from attached devices.
I have just noticed that MANY of my attached devices are not showing in the router menu pages. In either the basic or advance menu the attached devices show 11 devices. When I use a port scanning p...
- Dec 18, 2020
Well, 5 days later and I will call this issue fixed.
Moving the RBR to the other end of the basement (was 8 feet away from one of the RBS) has solved my issue. I just don't understand how this would cause the issue. I get that them being to close together could cause client issues, but everything was still connecting. It just was not listed in the attached devices page. Any insight as to why? Not that I need to know, but I would enjoy knowing.
Thanks again for all the help!!!!!!!!!!!!!!!!!
Dec 13, 2020Guru - Experienced User
:smileywink:
gwbaker
Dec 18, 2020Guide
- FURRYe38Dec 18, 2020Guru - Experienced User
Having two overlappting wifi signals too close to each other can cause problems. Sounds like you finally found the sweet spot. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
