warpdag
Jan 25, 2020Apprentice
RBR850 Massive Security Fail - Many ports responding to requests
Just bought the thing, using the latest firmware V3.2.9.2_1.2.4. Did not Disable Port Scan and DoS Protection. WAN ports respond to unsollicited requests, instead of ignoring. They do respond clo...
May 24, 2020Guru - Experienced User
Yes, I think were done. FW has been updated and seems it was finally fixed. Thank you NG.
I recommend users update there FW if there concerned about Orbi security.
Good Luck and enjoy.
